44 LP
Howard H.
03-26-2007 09:42:37
What is the difference between a "regular old" 44 Massey on LP versus the LP Special version??
Thanks,
Howard
Bruce Colbourne
03-27-2007 18:01:52
 Re: 44 LP in reply to Howard H., 03-26-2007 09:42:37
The model 44 and 44 special used the same engine in the LP models the following are the specs for the engine. [Continental]Model H260;Cylinders:four:Bore3-7/8 inches;Stroke5-1/2 inches;Displacement:260 cubic inches;Compression ratio:8.7 to 1,Firing order:1,3,4,2;Pounds compression cranking speed:108 to 190 pounds. The main differences were in the tractor itself.Longer u-frame,cast hubs on the front axle,rear wheels mounted with pinch type clamps,bigger feul tank, different upper steering shaft assembly,different platform,different seat mount,bigger front tires. The 444-LP used the H-277 model engine.
MH44-Special
03-27-2007 17:05:56
Actually the 44 Special LP version, (if it is truly a factory equipped model, should have a "B" in the first letter of the serial number after the '44', like 44BIRF), also used the Continental 260 engine and not the gasoline version's 277.
Howard H.
03-27-2007 19:02:11
 Re: 44 LP in reply to MH44-Special, 03-27-2007 17:05:56
Thanks for the info!
Would a true LP Special be worth much more than a regular LP 44??
I've mainly read up on JD's and MM's since they are more common out here, but have a couple of Massey Harris's and really like them...
Howard
Ian Johnsen
03-26-2007 21:35:42
The difference should be the displacement. 260 vs. 277 cu in.
