M H 44, Rear Hub Removal
W R
03-26-2007 02:07:31
Anyone had experience in removing the rear wheel hub from the axle on a MH44.
W R
04-05-2007 03:08:35
 Re: M H 44, Rear Hub Removal in reply to W R, 03-26-2007 02:07:31
Removed rear wheel hub on a M-H 744D to-day, made 3 pullers before I got one strong enough to last. On the last one I used an 18"dia x 5/8"thick plate and an 1,1/2"dia bolt & nut.The nut was welded to the drilled plate, then 2 flat bars 2,1/2"x1/2x12" were welded edge on across the plate & to the top of the nut.The puller was secured to the hub by 2, 3/4"bolts, using the tapped holes provided.The 1.1/2" bolt was tightened using Stillsons &pipe,.(4.5ft total lenght). Thanks for you replies to my question.
redbastrd
03-27-2007 03:09:34
There is a tapered pin that is in the hub. I drilled out the pin so the key would not come out with the hub, The pin goes through the hub and into the key on the shaft. I made a puller out of a piece of 1" steel, drilled the bolt pattern from the hub into the steel plate and drilled and tapped a 1" fine thread hole in the center, really saved alot of pounding.
mattlansing
03-26-2007 17:10:15
WR, I just removed on off my 44 yesterday, get the bolts out, and then knock off the cap on one side. Then I took a power wirewheel and polished up any exposed shaft. Then I heated the hub where the key is on both ends, as I took a 4x4 oak block and started to hit i back and forth. after about 10 hard blows, (that is why i use wood not to bust the hub) it started to move, and as it moved I would clean and lub the shaft. Hammer it off and then hammer it one, as you clean an lub and hten it is off. Hope it helps.
mn.Chuck
03-26-2007 05:12:37
Hi, Have done some many years ago. Soak-soak for
days with favorite chemical. Heat hot as possible,
with bolts loosened and drive inward with a heavy
mall or the best is to drive in with something
like another heavy axle shaft. After lots of "blows" it will start to move. Drive in till it
loosens a bit before you clean up the shaft and
go outward and remove. Cheaper than lifting wts.
at the health club. Good luck, Chuck
