MF 202 Wouldn't Start. Help Please!
Daniel
09-12-2000 19:21:37
My MF 202 died while bushhogging. It cranked but wouldn't start. Check the spark plugs and they were all blackened (covered with carbon). Changed 4 new spark plugs, it started and run again. But after about 20 minutes, it died and wouldn't start again.
This is my first tractor. Bought it 2 months ago and barely used it. Don't know much about tractors. Need some help to get it running again.
Best Regards!
pierce fallon
09-15-2000 11:47:55
 Re: MF 202 Wouldn't Start. Help Please! in reply to Daniel, 09-12-2000 19:21:37
well have you checked the air filter , this should be removed while trying to start. Or if you follow the spark leads to the distributer and examine the unit for corrosion espically the inner part of the unit ther are electrodes if these are corroded clean them and replace cap.Also check the coil is not gone. pierce
