135's hydraulic position lever not working...need
Scott Tekavec
03-23-2007 12:24:54
I was pushing some brush with my scrape blade in reverse yesterday when after a particularly hard shove the hydraulic position lever wouldn't raise the scrapeblade unless I moved the lever all the way past the stop to the constant pumping section. Did I break something while ramming in reverse or did I just knock the lever or arms out of adjustment. I do have the tech manual and it looks like I'll have the remove the entire upper assembly that's under the seat to readjust the arm linkage. Does anyone have any ideas on what might have happened and how to fix it? BTW it's a 1966 MF 135. Thanks in advance, Scott
Willy-N
03-23-2007 15:05:14
 Re: 135's hydraulic position lever not working...n in reply to Scott Tekavec, 03-23-2007 12:24:54
Lot of little parts under the Hydraulic Cover that could break of come apart. I have a complete spare system if you happen to need a part from top plate down to hydraulic pump all out of a 67 MF135 Orchard. Mark H.
