MH 30 162 continental engine
Larry in WI
03-23-2007 07:37:17
Anyone out there have a GOOD 162 4cyl engine that's ready to run for sale? Even a real good short block is o.k. I have a MH 30 that I don't use much but the engine is really worn out. Terrible blow by and fouls plugs. I don't want to sink a ton of money in it because as I said I don't use it much so if I could find a decent engine I think that's the way I would go.
Thanks, Larry
MMB
03-24-2007 17:10:41
 Re: MH 30 162 continental engine in reply to Larry in WI, 03-23-2007 07:37:17
You couldn't get much cheaper than to put a set of rings in and do the valves on a flathead Continental 4-cylinder. So you buy someone elses "good engine" and then you find out it's much the same as what you already have.
Larry in WI
03-25-2007 09:54:04
 Re: MH 30 162 continental engine in reply to MMB, 03-24-2007 17:10:41
You are so right. After thinking it over I decided to overhaul it. The engine is out and tore down.
Thanks, Larry
