Mustang Brake seals
G Elppa
03-21-2007 10:53:55
I have noticed considerable leaking at the bottom of a Mustang Brake Housing. Is there a seal inside that can easily be replaced?
Larry Martin
03-21-2007 16:24:16
 Re: Mustang Brake seals in reply to G Elppa, 03-21-2007 10:53:55
There is a seal in the differential that you need to replace. It is not easy as you have to pull the axles and remove the axle assembly to get to it. While you have it down you might as well replace the other side and check the bearings.
