has any one worked ona 184-4?
pjbrown
03-21-2007 09:23:02
I have a 184-4 that the three point hitch is weak... will not lift much. The pump is new and all the filters are clean. Has anyone ever work on one before? Thanks
DavidP, South Wales
03-22-2007 15:42:33
 Re: has any one worked ona 184-4? in reply to pjbrown, 03-21-2007 09:23:02
Hello, have not worked on a 184 before but I know the tractor and assume that the chassis is fairly standard MF. I may be wrong.
If it is MF type, place the DRAFT lever in its lowest position and check for endfloat where the top-link is attached to the tractor. If you have end float here, this is a possible cause and needs to be rectified.
Please ley me know what you find. I will not be available until next Friday.
Cheers
DavidP
