Massey Ferguson 65 Dieselmatic Year?
MarkY
03-21-2007 07:26:45
I was given my grandfathers 65 Dieselmatic and I do not know what year is is. It contains a S/N of 686607 can someone tell me the year of this tractor? It also has the multipower lever which I do not know what it is supposed to do, can someone explain that to me because I do not know if it is working.
Thanks!
135 Fan
03-21-2007 15:47:55
 Re: Massey Ferguson 65 Dieselmatic Year? in reply to MarkY, 03-21-2007 07:26:45
The multi-power lever gives you a 2 speed shift on the go in any gear you are in. It will free wheel in low. When you're driving a long and shift it up or down you should speed up and slow down a bit. It makes a bigger difference the higher gear you are. It works good if have some tougher ground when pulling implements. Just flip it down without the clutch and it will slow you down and give you more power. Dave
Grampa Leon
03-21-2007 14:23:36
My source shows MF65 686607 built 1962,no info.on
power lever.
