massey 44 cam timing
Jared Chaddock
03-19-2007 16:57:05
I am still in the process of rebuilding the H260, and I have some question about the marks on the timing gears...I have two sets of gears, and the marks arent really that clear on either set. Im wondering if someone can verify what I think are the correct marks. If you look at either cam gear or the crank gear from the front and drew a straight line from the center outward thru the centerline of the key way, the cam gear marks would be on the 14th and 15th teeth counterclockwise from this point. On the crank gear, it would be 4 teeth clockwise from this point. I hope this isnt too confusing, and thanks to anyone that can help.
