MF35 WON'T TURN OFF
PETE LARSEN
07-24-1998 12:29:01
My MF35 diesel starts and runs OK; but when I pull the lever that cuts the fuel supply off, the engine speed slows down but doesn't stop! Do I need to pull the fuel box off and have it serviced or is something else out of adjustment?
Jack in NB
07-26-1998 06:48:59
 Re: MF35 WON'T TURN OFF in reply to PETE LARSEN, 07-24-1998 12:29:01
Hi Pete -
Sounds as if the shut-off control rod isn't pulling the shut-off lever (on top of the injector pump) completely to the end of it's travel.
Try moving the inner end of the lever on top of the pump fully to the rear of it's travel. Chances are the rod may be binding, possibly at the sdjustment nuts right near the knob. If the knob is still there!
Good luck.
