MF65 Wheel
hdlong
03-19-2007 04:58:06
My mf65 has spin out rims and one side moves in and out approx.2 1/2" - 3" How do you rebuild clamps or can you weld stop blocks on rails so they dont move I have no need to adjust in and out.Anyone have regular style rims (none spin out)for sale or trade
massey333
03-19-2007 15:11:24
 Re: MF65 Wheel in reply to hdlong, 03-19-2007 04:58:06
It doesn't sound like you have the factory stops on your wheels,because the rim CAN'T move on the wheel if they are on there.One on each side of the clamps.
DavidP, South Wales
03-19-2007 09:46:49
Hello,
On this side of the pond we call them PAVT rims (Power Assisted Variable Track). 'Spin-out' is easier. I assume that the clamps will not tighten. This is probably due to the bars on the outer rims being worn, in which case you either have to widen your track or change the wheel rims side for side and turn the tyres. I have done this with a MF 595 recently with total success. In this instance I was able to set the wheels at the number 2 out position which lined up nicely with the front axle settings. If your clamps are worn they should be replaced. In the UK they are available from a non-genuine source. Don't forget to check the tightness regularly.
DavidP
vapet
03-19-2007 08:51:07
These are 12 inch adjustable two piece rims, bolt together. Was going to use on my 65. My rims are 12 inch wide with 14.9 tires. Sure you measured corect? I live in southwest Va.
hdlong
03-19-2007 09:50:17
 Re: MF65 Wheel in reply to vapet, 03-19-2007 08:51:07
Will I didn't measure rims myself but a few years ago when tire service came out to put new tires on thats what size I was told and 13.6x28 was the largest size they would mount. Wanted 14.9s.My tires like new afew nicks here and there.Will 13.6 fit on 12"rim
vapet
03-19-2007 09:56:57
 Re: MF65 Wheel in reply to hdlong, 03-19-2007 09:50:17
Measure your rims and get back. If 11 they are of no use to me. May sell these to you pretty cheap.
hdlong
03-19-2007 11:36:26
 Re: MF65 Wheel in reply to vapet, 03-19-2007 09:56:57
Could you send picture and price of your rims.I'm about 99% sure mine are 11" Thank You!
vapet
03-19-2007 12:30:05
 Re: MF65 Wheel in reply to hdlong, 03-19-2007 11:36:26
Will do tomorrow.
Vapet
03-20-2007 09:51:50
 Re: MF65 Wheel in reply to vapet, 03-19-2007 12:30:05
email and will send pictures.
hdlong
03-20-2007 10:19:39
 Re: MF65 Wheel in reply to Vapet, 03-20-2007 09:51:50
Email hdlong49@yahoo
vapet
03-19-2007 08:19:01
Have a set off a John Deere that will fit. Would trade with you if your rims are in good condition. Also depends on your location.
hdlong
03-19-2007 08:32:30
 Re: MF65 Wheel in reply to vapet, 03-19-2007 08:19:01
I'm in east central Ohio my rim size is 11x28 the rims are good.Are your rims 1 piece style
