No hydraulic pressure
Wood Chopper
03-15-2007 15:12:55
A Massey friend has a 1976 model 230 and tells me he has no hydraulic pressure to his loader - even after 1/2 hour running. It is located in Colebrook, NH and has been in a very cold garage for some time. The oil level is fine.
Any advice apreciated.
Dennis
DavidP, South Wales
03-17-2007 08:59:21
 Re: No hydraulic pressure in reply to Wood Chopper, 03-15-2007 15:12:55
Hello Dennis,
Check the the isolating valve (if fitted) under the seat is in the correct position for auxillary hydraulics (loader etc). Check if the 3 point linkage is working. If it is a 230 as per UK spec it is likely that the loader will operate from the Ferguson pump. If you have no 3 point linkage we need to look furter. If no isolating valve is fitted, make sure that the position lever is in the CONSTANT PUMPING position.
DavidP,South Wales
