Re-route hyd on 44 Spec.
JEFF88
03-15-2007 07:45:45
Can a person simply bypass the Depth-O-Matic unit under the seat and route the hydraulic fluid back to the reservoir after flowing through the control stick? I don't need the D-O-M for anything and see no point in taking it apart to clean out dirt or replace parts. The front end loader lifts OK but lowers slowly, and only if the control stick is held in just the right position, part-way back. Control stick unit was checked out OK. So am assuming something's wrong inside the D-O-M. I may be forgetting something in wanting to bypass the under-seat unit. Will the loader work just as well without routing through the D-O-M? Thanks for the info.
STUDIEDIESEL63
03-15-2007 19:59:30
 Re: Re-route hyd on 44 Spec. in reply to JEFF88, 03-15-2007 07:45:45
Look on the ram end of the depth o matic cylinder ,see if there`s a hex nut with a rescessed screw in it. thats the valve to lock out the d.o.m.cylinder from extending or retracting. run the cyl. out then loosen nut turn screw in,tighten nut.valve will be lower left as you stand behind tractor ,if your tractor has it,as some didnt.if the lines are plumbed right it`ll work much better.
