MF 2745 doesn't go into reverse
corky
03-13-2007 18:42:12
I was told this could be as little a problem as some o rings. I don't know where they are located. Appreciate the help.
Corky
04-16-2007 19:31:03
 Re: MF 2745 doesn't go into reverse in reply to corky, 03-13-2007 18:42:12
Definitly the O-Rings. The bad thing is that you will need to split the tractor to repair it. They get cut when there is play in the shaft for the power shift. You should expect to machine the housing, replace the clutch packs, and obviously o-rings. I was told by the local Massey dealer to expect $1000 in machine work, $700 in parts, and $1800 in labor.
jogl
03-14-2007 04:52:50
Have you checked the shifter linkages? There is a rubber or neoprene spider that connects the power shift / reverse shifter to the shaft coming out of the transmission that I have had to change before. Also the linkage occasionally needs adjustment.
I haven't had the tranny apart yet so can't help you with the internals.
I have read in other old posts that as soon as the tranny starts acting up that you should stop using it. At that point it may only need o rings and seals. But if you keep using it you can burn the friction surfaces out.
Let us know what you find and good luck,
JP.
