Overheating 1030 Massey Ferguson
Greg Drain
09-10-2000 12:59:23
Model No. 1030, Serial No. 40835, Series No. 2963
I have an overheating problem and need suggestions. I have already changed the headgasket, the thermostat, hoses, waterpump, checked for a warped head & radiator problem. Does anyone know a reason this may be happening? There is no water in the oil. Thanks for your help!
mike
12-15-2003 07:58:32
 Re: Overheating 1030 Massey Ferguson in reply to Greg Drain, 09-10-2000 12:59:23
Try replacing radiator cap
John Greer
09-09-2003 15:54:14
If it heats up slowly as it is used, it is over loaded. If it just heats up, but does not stop running, the only other solution is the gauge is bad. That is about all that is left. Good luck.
I am trying to find a shop manual. Will you sell me a copy of yours? Thanks.
mike martin
09-10-2000 21:22:18
is this a diesel or a gas. if it is a gas check your timing to speck. if it is a diesel check for wear in your pump drive and see what this does for you uyr pump drive. see what this does for you.
Bob Lyczewski
09-10-2000 21:16:24
Seems like you have done the right things so far. Did you check the radiator flow and flushed out the block?
