MF 3090 power stering problem
Marcin
03-11-2007 04:44:04
I have MF 3090 and power steering problem just arrived. It is not easy to turn left or right with steering wheel. When tractor is standing still or moving it is always hard to turn steering wheel. What can be the problem?
LM
03-12-2007 05:23:01
 Re: MF 3090 power stering problem in reply to Marcin, 03-11-2007 04:44:04
Hi, I had a similar problem on our 3090, the steering would get very heavy when the tractor had been running for a few minutes, problem turned out to be the main hydraulic filter was blocked. This filter is located under the cab on the right hand side just in front of the back wheel. I took off the filter and washed it out, the steering was fine straight away.
I fitted new filter and changed the hydraulic fluid after that. However I think (open to correction on this)that some 3000 series tractors had a seperate filter for the steering system, this should be checked too. There is only one filter on our one.
richard in nz
03-12-2007 01:03:04
1 Siezed front swivel bearings or lower bearings collapsed.
2 Blocked suction filter.
3 Wrong grade of oil or oil level very low.
4 Pump faulty.
5 Danfoss unit faulty. I have had all these problems with M-F 3000 series steering some with a combination of causes. Check the mechaical state of the front axle then start doing pressure and flow checks.
