oil drain plug
JJ in OK
03-06-2007 18:39:43
I am in the process of rebuilding my 65. While I have everything scattered all over my shop, I have misplaced the drain plug for my rear end. Is this something I can order from the dealer or try to match up one from a parts house? Thanks JJ in OK
Don-Wi
03-07-2007 00:08:35
 Re: oil drain plug in reply to JJ in OK, 03-06-2007 18:39:43
I'm not familiar with the 65's, but it is a plug on the side similar to the engine drain plug, or is it just a pipe plug? You can get either fomr the dealer, but if it's a pipe plug just go to the hardware store.
Donovan from Wisconsin
JJ in OK
03-07-2007 03:18:48
 Re: oil drain plug in reply to Don-Wi, 03-07-2007 00:08:35
Its the same drain plug as used on the engine oil pan and the transmission pan. It has an 1 1/16" bolt size on it. If I can get it from the dealer, I will go ahead and get 3 new coppper gaskets. Thanks
mike a. tenn.
03-07-2007 03:21:53
 Re: oil drain plug in reply to JJ in OK, 03-07-2007 03:18:48
don...you might find out that's a magnetic plug to help gather small bits of loose metal. i'd try and get a replacement if it is.
-mike
