354.4 perkins oil passage
JD Ogden
03-05-2007 19:17:31
I am putting a combine motor in a tractor and need to know about the oil passages on the left side of the block. the passages are where the oil cooler used to bee I am moveing the cooler to the right side and I am left with an extra hole that I need to know if I can plug this hole thanks
DavidP, South Wales
03-06-2007 02:03:19
 Re: 354.4 perkins oil passage in reply to JD Ogden, 03-05-2007 19:17:31
There should be no problem as long as you use a plug of the correct thread. Ensure that you supply and return points to the block or take-off point are as large in bore size as possible so that the flow is not reduced in any way.
DavidP,South Wales
