compression test MF165
JAT
03-05-2007 09:50:28
What should the compression be on a 165 gas engine (Continental G176)?
I did a compression test today and the numbers were (front to back) 120psi, 130, 145, 140.
JAT
03-05-2007 18:50:12
 Re: compression test MF165 in reply to JAT, 03-05-2007 09:50:28
Problems. No power at all. 3 of 4 cylinders bridge the plugs with carbon in less than an hour of run time. 1 plug was covered in oil when it was pulled.
Jerry/MT
03-05-2007 21:00:19
 Re: compression test MF165 in reply to JAT, 03-05-2007 18:50:12
Did you conduct the compression test on an engine at operating temperature with the throttle plate wide open and no air filter resitriction? If you didn't then I'm not sure what thecompression numbers mean. If your plugs are fouled by a soft, sooty deposit, your mixture is to rich and your carb needs adjusting. If it's a wet, oily deposit, then your oil rings have lost oil control.
JAT
03-06-2007 04:46:25
 Re: compression test MF165 in reply to Jerry/MT, 03-05-2007 21:00:19
No, the test was done cold - I guess I'll have to do it again sometime when it's hot.
The plug on cylinder #3 always has oil on it when I take it out but the engine never smokes when it's running. Doesn't that sound odd?
How do I go about adjusting the carb?
Jerry/MT
03-06-2007 10:55:28
 Re: compression test MF165 in reply to JAT, 03-06-2007 04:46:25
You may just have a bad valve guide and/or seal on the intake valve for # 3 so that it only see's a lot of oil when it's at idle and clears up as you open the throttle and reduce the manifold vacuum.
I don't know what kind of carb you have but if it's a Marvel-Schebler, there will be a big screw on the fuel bowl. Screw it in lightly til it stops and then turn it out 1-1/8 to 1-1/4 turns. Start it up and let it warm up and then acclerate the engne from lo idle to high idle. It should accelerate smoothly with coughing or missing. never go be low 1 turn full open.The Continentals depend on charge cooling from slightly rich mxtures to keep the exhaust valves from burning.
If you don't have a shop manual for your machinne, get one and it'll have the instructions for you specific machine. I'm sorry i don't know much about the MF165
The Preacher
03-05-2007 16:14:53
Sounds fine to me. They recommend that compression pressures be within 10% from one cylinder to the next, but 120-145 indicates good sealing rings and valves. Most of these old engines ran anywhere from 80-150 psi, so yours sounds like it's in great shape. Are you having problems with it, or were you just checking for the heck of it?
