M-H 44 Oil Pressure
kpowl
03-05-2007 05:00:23
I recently purchased a M-H 44 that has not ran in a year. I brought it home and changed the fluids and filter. I put 30 wt. oil in the engine. When the tractor runs it has between 15-18 lbs of oil pressure. Does this sound right? The gauge does not move between an idle or wide open. When you start the tractor it immediately goes to 15-18 and does not vary. I have a couple of Farmall tractors that seem to carry more oil pressure than this. Thanks for any info.
kpowl
03-06-2007 04:34:45
 Re: M-H 44 Oil Pressure in reply to kpowl, 03-05-2007 05:00:23
Gentlemen, thank you very much for your time and information. I feel more relieved now.
mn.Chuck
03-05-2007 18:57:07
My 44 repair manual states 10-20 lbs. You are good
to go. All Cont. built engines that I know do not
run high oil press. Massey called this engine their own engine but was still built by Continental. Chuck
JJL
03-05-2007 06:28:29
Your oil pressure is fine as long as it is a gas engine. 15-20 lbs is what all of ours run. Engine speed does not make any difference either.
