mf65
hdlong
03-03-2007 17:46:05
how to remove ring gear from rearend of mf65 gas tractor has noise and trying to figure out where its coming from.the wheel axle has a lot of play in the drive cover and had new bearings last spring i have axle houseing off to the rearend and ring gear moveuand down is this normal
Eric in IL
03-04-2007 05:33:52
 Re: mf65 in reply to hdlong, 03-03-2007 17:46:05
The complete differential assembly is removed from the left side of the tractor. Left side refered to as if you are sitting in the seat. The ring gear will come out with the differential. If you have one or both of the axle housings off, chances are that the differential carrier plate/plates have also been removed. IF this is the case, up and down movement of the ring gear will happen as it would have no support from the carrier bearings.
We really need more information to offer much help. When did the noise start, was it after the new bearings you speak of were installed? Could the noise be coming from the planetary gears out by the wheel? Exactly which bearings were replaced?
