massey 1150 serial #
david austin
03-02-2007 10:23:04
can someone tell me what year it is? Also what is this large canister on the side of the tractor? Oil filter ? is it necessary? this tractor had a cab on it and does not now.
david austin
03-02-2007 10:25:09
 Re: massey 1150 serial # in reply to david austin, 03-02-2007 10:23:04
sorry just gettin the hang of this stuff serial number 9B 28100
V8 farmer
03-12-2007 13:38:16
 Re: massey 1150 serial # in reply to david austin , 03-02-2007 10:25:09
Hi there,
It is a late 1970 model.
I think the canister you're talking about is brake accumulator. If its on the RH side in front of the fuel tank, that must be it. It's purpose is to keep pressure in the brake system when engine is not running. Very vital on these tractors since brakes work off tractors main hydraulics.
Greetings,
another MF 1150 owner
david austin
03-13-2007 04:15:42
 Re: massey 1150 serial # in reply to V8 farmer, 03-12-2007 13:38:16
this thing looks like it has been added it holds about 2 gallons of oil and is hosed into the oil filter housing and back into the base of the engine with a huge metal lift out filter in it im sure its an oil filter but Why? i havent seen it on any other to date or in the shop manual. Question is do the 2 standard oil filters pereform the task and if so why would anyone add this?
V8 farmer
03-13-2007 16:05:24
 Re: massey 1150 serial # in reply to david austin, 03-13-2007 04:15:42
I would've suggest its an oil cooler of later type used in 540 and 640 Perkins engines. But they are smaller than 2 gallons so I don't know.
