9N and a brush hog?
Kathy Hyde
03-01-2007 18:30:21
Okay one more? Can my 2N handle a 48" brush hog?
TexMac
03-01-2007 20:52:52
 Re: 9N and a brush hog? in reply to Kathy Hyde , 03-01-2007 18:30:21
Used a 5 footer for years on my 1941 9N on heavy grass and light underbrush (nothing over 1 inch in diameter). Four foot would have bogged down less, but would not have overlapped tire prints.
ORC (over running clutch) - a PTO shaft extension with a ratcheting clutch built into it. Keeps the shredder blades from acting like a big mother flywheel and pushing tractor into barbed wire fences, creeks, and trees when you depress the tractor clutch to stop. Clutch on early Ns and Fergusons does not decouple rear wheels, only the engine. Easy to get hurt or killed without one.
Dave_Id
03-01-2007 19:03:51
It should handle it easy, but it depends if you are trying to mow down large diameter trees. Make sure you use that run-on adapter on your pto shaft, can get them at any farm supply store for around $50.
Kathy Hyde
03-01-2007 19:55:03
 Re: 9N and a brush hog? in reply to Dave_Id, 03-01-2007 19:03:51
Again thanks Dave. I'm not sure what a run-on adapter is on the PTO. I have an adapter to run my hay elevator.
Gerald J.
03-01-2007 20:34:30
 Re: 9N and a brush hog? in reply to Kathy Hyde , 03-01-2007 19:55:03
Run on clutch or coupler is generally called an "overrunning clutch." Its needed when using a mower on the Ford N series tractor because the PTO shaft is the side shaft in the ground driving transmission. That means if you don't have an overruning clutch in the mower drive and try to stop with the clutch on the tractor when driving up to a pole or building that the spinning flywheel that is the mower blade will continue to drive the tractor and brakes added may not stop it. If the building or pole is sturdy, the tractor nose may be shortened significantly.
Most farm stores have overruning clutches, some even with the 1-1/8" spline of the Ford N tractor on the input and the modern standard 1-3/8" 540 RPM PTO spline to fit the PTO drive shaft.
Gerald J.
Kathy Hyde
03-01-2007 21:15:31
 Re: 9N and a brush hog? in reply to Gerald J., 03-01-2007 20:34:30
Again you all have amazed me. Great information. Sounds like a brush hog would work akay with these additions for safety. Mostly need to cut smaller brush like snowberry, buck brush and wild rose.
