MF 255 battery
FarmnPoor
03-01-2007 10:16:35
Does anyone know the correct placement of the battery on a 255? At this time the battery is sitting in the front of the tractor in front of the radiator, but there looks like a spot for a battery under the steering console also. The reason i ask is that the battery in it know has leaked or spilled some acid and im worried about it being next to the radiator and steering cylinder. Looks like it could cause some damage.
Also, There is small cooler in front of the radiator. Is this for hydraulics/transmission? does it require maintenance?
Thanks
m.f. info.
03-04-2007 19:14:30
 Re: MF 255 battery in reply to FarmnPoor, 03-01-2007 10:16:35
the correct location of the battery is in front of the radiator. the cooler only requires keeping fins clean of debris.
MF Poor
03-01-2007 11:22:55
Does the tractor have multipower tranny?
FarmnPoor
03-01-2007 20:49:57
 Re: MF 255 battery in reply to MF Poor, 03-01-2007 11:22:55
It does not have multipower. It is a 1975 model.
MF255?
03-01-2007 11:12:23
A 1976 255 w/203D has it like yours. I've seen them around the steering on the smaller 245. Check that front area more often and replace the leaking battery. Don't know about the small cooler, maybe for the power steering. Keep the radiator fins clean for better cooling. The 255 is a great tractor!
