Starving MF50
Ken Le MOAL
02-24-2007 17:07:27
Starving for fuel MF50 my massey runs fine for 5 minutes or so then starts to starve for fuel, I drained the tank and took out and cleaned the petcock, when I put it back together I had to loosen the sediment bowl for it to refill, is this normal? I checked for a fuel filter at the carb but dont see one. I have even tried running it with the gas cap off in case it was an air lock. I have ran out of ideas can someone help?PS its a gas tractor' thanks.
Jerry/MT
02-25-2007 17:06:46
 Re: Starving MF50 in reply to Ken Le MOAL, 02-24-2007 17:07:27
How do you know "...it's starving for fuel..."? Do you have a good spark when it stops running? When it dies on you, pull the center wire out of the distributor cap, hold it near a good ground, turn on the ignition and try a start. You should have a FAT, BLUISH WHITE SPARK. If you don't the problem isn't fuel it's fire! You need to sort out the primary ignition circuit. Running for 5 minutes and dying could be cause by a bad coil or a bad key switch.
If you have a FAT, BLUISH WHITE SPARK, then suspect the fuel delivery. To check the system, open the tank valve and holding a suitable container under the carb, remove the drain plug. Fuel should CONTINUOUSLY gush out like a cow peein' on flat rock for at leasdt a minute! These old tractors often sat in the back 40 for years and the fuel tanks rusted and collected all sorts of crap and corruption. If you don't get a continuous gush of fuel there maybe a clogged screen in the fuel inlet elbow at the carb, the sediment bowl filter may be clogged, or the fuel line kinked or clogged.
If you have good fuel flow at the carb inlet elbow, but not at the carb drain plug, it's possible that your float valve is stuck (rap the side of the carb with a block of wood) or the fuel bowl is filled with fine crud and won't let the float drop or the float valve is clogged. The latter will require that the carb be throughly cleaned and blow out with compressed air and reassembled with new gaskets.
Rod in Smiths Falls, ON,
02-25-2007 05:41:38
Next time it does it take a bolt and tap the carburetor just outside the float a couple of times. If the engine starts right up after this, your float valve is worn and hanging up.
David Maddux
02-25-2007 03:54:29
Also check that the air cleaner has not plugged up. On the Allis Chalmers tractors, we have had to pull the wire mesh out of the canister and wash it out.
mn.Chuck
02-24-2007 19:23:00
Ken, The sediment bowl assy. can become partially
plugged inside and there is no way to manually
unplug. A good carb cleaner would unplug if left
to soak. We used to deal with some as a service
call so would replace the sed bowl assy. They are
not too high priced and saves some labor to just
replace it. Chuck
Lloyd B. East
02-24-2007 19:06:31
I have a MF 50 gas and it does the same thing kind of. I haven't used it much but it was starting and running for a few minutes and then it just shut down. I did rake some hay with it and it did O.K. The carb seems to be running rich because it is smoking black smoke. I kind of thought it was fuel related on mine.
Aaron Ford
02-24-2007 19:03:08
Well, a good check of this would be to drop the plug in the carb bowl and drain out a gallon or two to see if the carb inlet elbow screen is plugged. This can be replaced with a non-screened elbow if it cannot be cleaned. Disassembling the carb and checking for blocked bowl vents might be an idea. Let us know what you find.
Aaron
Heck if you are close to northern WV, drop a line and I will come scratch my head right beside ya.
Joe Ferguson
02-24-2007 18:08:48
It is normal that you had to loosen the bowl
it means that there is no leak in the line and the carb needle does not leak. If you had started the engine while the bowl was off then it
had filled because the gas chamber in carb had be empty.
Did you check the screen filter above the bowl ?
It may be an electrical defect....
There are some non expensive things to try:
When current is applied or/and engine normal heat
around....some components may fail and work again after cool down.
You may change the condenser inside the distributor.
Try another coil.
Install a jumper from the battery to the battery side of the coil...sometimes the ignition switch become resistive with age when passsing current.
My 2�
Joe Ferguson
