2705 weak reverse
majors1958
02-24-2007 11:30:51
all forword gears are fine,but in reverse you must be in low and on a flat surface to move. touching the brake will cause it to stop, release brake and it moves. no wierd noises or engine rpm change.24 speed transmission
jogl
02-24-2007 16:03:14
 Re: 2705 weak reverse in reply to majors1958, 02-24-2007 11:30:51
There is another old thread on this forum that says as soon as something funky starts happening with the 24 speed... STOP USING IT!!!
The explanation was that the orings and / or seals go first and if you catch it early that is all that you may need to replace. But if you keep using it you will wear all of the friction surfaces out due to low pressure on the hydraulic clutches.
Let us know what you find,
JP.
MF#1
02-24-2007 14:14:45
I hate to be the bearer of bad news but I was told when I had my 2805 that when reverse goes out the Powershift is heading south, which means $$$$.
