massey harris 20 dip stick
karl groom
02-21-2007 18:44:42
can anyone give me the measurements for the engine oil dip stick i am restoring a model 20 and the dip stick is missing so i will need to fabricate one i need the length to the cap and the distance to the full mark. thanks in advance for the info
MMB
02-22-2007 18:14:28
 Re: massey harris 20 dip stick in reply to karl groom, 02-21-2007 18:44:42
Those Continental engines were all the same for that series of engine block called the F400 block. Anyways, there is a thimble shaped cup welded near the top of the dipstick which is the stop as well as the protective dust cap which slides over the cylindrical stem into which the dipstick pushes into. The distance from the top stop (the inside top of the thimble) to the bottom of the dipstick is 9 5/16 inches. From the top stop to the full mark is 7 9/16" and from the top stop to the low oil mark is 9 1/8 inches. I'm going out into a back shed tomorrow and looking, I might have one here for you. Oh, one other thing. This one I am measuring is missing the small leather or felt washer that rests inside the thimble near the top stop, it would be the thickness of a regular piece of leather I would think. This one has been picked out but I know other ones I've seen have them in place. I don't think it would really make too much difference in reading the oil level whether it was present or not.
karl groom
02-23-2007 19:19:15
 Re: massey harris 20 dip stick in reply to MMB, 02-22-2007 18:14:28
thanks for the info if you have an extra you want to sell let me know. if not the info you supplied should guide me in the making a replacement
MMB
02-24-2007 05:53:15
 Re: massey harris 20 dip stick in reply to karl groom, 02-23-2007 19:19:15
Didn't get back to you yesterday. Can't seem to locate the one I referred to. Anyways, sounds like you have a good handle on making one. Good luck with the project ..... MIKE
