Amp gage not showing charge
R.J.
02-20-2007 22:13:05
On 285 the alternator is working, but don`t show on gage and current not getting to battery. Some told me there is a diode in the wiring harness someplace that is probably bad. Would this be the problem, and if so where would one look for it?
Thanks for you help.
R.J.
Crem
02-21-2007 17:38:27
 Re: Amp gage not showing charge in reply to R.J., 02-20-2007 22:13:05
On my 165 I had a loose connection on the ammeter itself which then burnt and corroded some.
Don-Wi
02-20-2007 23:27:33
Does the ignition swith work too? I think when ours does that it's the fuse for the instrument panel, but I don't think the ignition switch will engage the starter either when this happens.
I can't be too certain because it hasn't happened lately and it's in the shed.
Donovan from Wisconsin
