Putting a loader on a MF 255
pbutler
02-19-2007 17:05:54
I found a nice loader and brackets sized for my 255.
My question in around hydraulics. The loader comes with a joystick control-didn't see the hookups.
So what do to get the fluid to the loader values-i.e. open the circuit. Do you just take the current Remote and bungee the lever down or something? Don't want to damage the pump, I am just not understanding how this is supposed to work.
m.f. info
03-04-2007 20:38:39
 Re: Putting a loader on a MF 255 in reply to pbutler, 02-19-2007 17:05:54
attach hyd. hoses too aux.hyd. the same as any other hyd.lift equip. don't tie down control lever, if it has a detent in the up and down positions . select the up position normally ,try loader to see if it operates in reverse order, if it does change the position of hoses in in remote couplers. by not tying down control lever the detent will shut off hyd's. when system pressure is reached. if aux. hyd. is not detent type then hyd.lever will need to be tied down,only after making sure the loader valve has it's own relief valve, [[[in either case make sure what the loader manufactor's system pressure should be for your application.]]] this is simple way to supply hyd's.too your loader.
justplainjim
03-03-2007 15:50:05
I have a MF236 loader on a 255 tractor. First time around, picked up hydraulic juice via the remotes. Worked great until the auxilary pump gave out. Was told the aux pump can't take that kind of work. Now have a selector valve on top of the hydraulic cover (in front of the seat)to get hydraulic juice from the pump for the 3 point. One way allows the lift arms to work, other way allows the loader to work. Not a pretty installation but does work.
