crack in oil pan mounting hole-165D
lonestarjeff
02-12-2007 17:41:23
Noticed this crack while changing the oil this weekend. It's in the front left mounting hole of the oil pan.
third party image
How worried should I be? Anyone else had a crack develop there?
Jeff
DavidP, South Wales
02-13-2007 02:25:20
 Re: crack in oil pan mounting hole-165D in reply to lonestarjeff, 02-12-2007 17:41:23
HI, I don't think that you should be unduly worried about it. Slacken the bolt and see if it has cracked on the other side as well, if it hasn't...good. What I would suggest is fitting a very thick 5/8 flat washer under the head to spread the bolt load over as much of the casting as possible. Providing it is tight against the axle casting then the material is in compression and doing its job.
DavidP
Don-Wi
02-13-2007 00:52:29
Our 165 has a peice missing from the front end that bolts to the engine on the right side, and we still use it under a loader. Probably not the best thing to be doing with it, but it's been like that for a while now.
Donovan from Wisconsin
ric1
02-12-2007 17:50:20
i will check mine out to see if its cracked. RICK
