Steering fluid leak
Crazyman
02-12-2007 11:10:54
I have a mf 135 and it reained pretty hard and I am sure water got down the steering column because the steering box is leaking. How do I fix this and can I run it before fixing it? I want to get the water out. if any in there. Is it connected to the entire tranny system?
crazyman
02-13-2007 18:06:21
 Re: Steering fluid leak in reply to Crazyman, 02-12-2007 11:10:54
Thanks for all the help! I sucked out about 6 0z of water and some sludgy oil crap. I didn't have a large syringe so it took a while. I only had some 10w 40 laying around so I filled it with that for now I guess it will be ok Right unill I get a syringe that I can replace the entire fluid with. What kind of oil goes in there anyway so I can do It right?
JJ. in B.C.
02-13-2007 21:53:23
 Re: Steering fluid leak in reply to crazyman, 02-13-2007 18:06:21
When new the book recomends SAE30 but i'm goin' with somethin' a little heavier SAE 90EP gear oil.
HTH....JJ.
crazyman
02-13-2007 04:41:42
Thanks for the reply. I am not sure if I have a filler hole or not it is a manual steering setup. If so is there still a fill hole?
JJ. in B.C.
02-13-2007 12:08:08
 Re: Steering fluid leak in reply to crazyman, 02-13-2007 04:41:42
Yeah there's a small filler plug on top of tha box. I have the same problem with mine, it froze solid this winter, have ta keep a light bulb on it so i can use it. Gonna suck her out when it warms up some, bought a nice little suction pump from NAPA..... ...JJ.
DavidP, South Wales
02-13-2007 02:30:22
Hi,
I don't think it will make much difference whether you have the North American of European type box. If you suspect there is water present, insert a piece of plastic pipe into the filler hole and right to the bottom. Either suck it yourself (very cautiously) or use a syringe of some sort to draw out whatever is in there. If you can get the oil out it won't do any harm to replace it. Steering box and transmission are seperate.
DavidP
crazyman
02-13-2007 16:06:17
 Re: Steering fluid leak in reply to DavidP, South Wales, 02-13-2007 02:30:22
thanks
crazyman
02-13-2007 05:10:38
it"s a manual steering
DavidP, South Wales
02-13-2007 13:56:03
 Re: Steering fluid leak in reply to crazyman, 02-13-2007 05:10:38
JJ in BC should have the answer.
