65 Contental motor oil pan removal
JJ in OK
02-11-2007 15:47:11
I am trying to pull the oil pan off if my 1958 mod 65. I have all of the bolts out including the 2 on the front end/motor. My question is : do I need to support the front end and motor to loosen up the other 4 bolts that are attached to the motor? The pan will not move! I am affraid to beat on it too hard because it looks to be cast. Thanks JJ
Aaron Ford
02-12-2007 18:10:13
 Re: 65 Contental motor oil pan removal in reply to JJ in OK, 02-11-2007 15:47:11
It is cast. Very heavily constructed cast at that. There are 3-4 longer bolts recessed in the back of the pan. Make sure these are out. Tapping with a soft faced hammer (brass, plastic, or a wood block and a steel hammer) should pop it loose. I doubt you will damage it, but it would be prohibitively expensive if you did. Mine came down easily, but I did have to tap on it to break the gasket seal loose. Good Luck, Aaron
