Throttle adjustment on 165
RH in KY
02-11-2007 09:57:10
I have a 165 with a Perkins. It idles too fast and I want to slow it down. My question is do I need to adjust it by taking the top off the fuel injector pump, or can it be done a different way?
DavidP, South Wales
02-13-2007 02:46:03
 Re: Throttle adjustment on 165 in reply to RH in KY, 02-11-2007 09:57:10
Hi,
First of all, is the throttle linkage returning fully? Linkages wear, work dry and generally stick from time to time. If the lever on the pump is returning to the adjustment screw then all it needs is a tweak here. Screw out to slow down. If the linkage is not returning normally a spring between the front of the throttle rod and fuel inlet pipe will do the job. DONT remove the cover!.
DavidP
