Massey 135
Grandpa's 8N
02-10-2007 07:40:45
Early gas massey 135 coming up on a sale. Haven"t looked at it yet. I couldn"t find in the search the capacity of the three point. How big of a round bale can I lift. Don"t do it- 1000 pounds, 1250 lbs, 1500 lbs. I believe it is a catagory one.
mlauk
02-10-2007 19:50:03
 Re: Massey 135 in reply to Grandpa's 8N, 02-10-2007 07:40:45
I picked up a 4 x 6 roll of hay with a 3 point hay spear on my MF 2135 (industrial version of a 135) and the hydraulic system knocked like crazy. It picked it up, but there is a hydraulic relief valve or something that starts knocking when it gets to its limit. I've also picked up a 4 x 6 roll with the front end loader (MF 200) which picked it up no problem, but I didn't have much traction, even with an 8' blade on the back.
massey fan
02-10-2007 12:37:34
Hi,i have a mf135 diesel,we use it all winter to move round bales weighing 1/2 tonne on a spike on the rear 3 point linkage with no problems.Steering is lighter but it is still good to steer,even at 16 mph on the road.The spec for uk diesel tractors says it will lift 2850 lbs but you would need alot of front weights to keep the front down.I think that it is way too much to be safe. Hope this helps
Gerald J.
02-10-2007 09:46:23
I tried a Deere three point cultivator. 4 row wide, converted to 6 row narrow, had one less rig. My MF-135 would lift it with cold oil, but not with hot oil. Same thing with a 15' wide JD 400 rotary hoe. And had to steer with the brakes when the implements were in the air.
Last couple years with a sprayer on a wooden frame sitting on a three point platform, when I fill the 65 gallon tank, I had to add 200 pounds of front wheel weights to have any steering at all, and still if I'm not gentle on letting out the clutch the front wheels may be in the air. The three point lifts OK for that load (sprayer probably doesn't weigh 200 pounds all together when dry).
Longer ago I tried hauling round bales with the MF-236 loader that was mounted. I had to fill the rear tires all the way with calcium and hitch a 3 point bucket and fill it with dirt to have the back wheels on the ground half the time. One session of that and I hired the bales moved with a larger tractor and when I bought a JD 4020 I moved that loader to the 4020 which hasn't yet broken it. It was too much loader for the 135 which shows in the welds at the center of the 135 front axle.
Its not enough tractor for your task.
Gerald J.
mike a. tenn.
02-10-2007 08:02:47
G-8...never weighed any of our bales, but they're 5' by 5', and will lift the front end of the neighbor's 135 so that you have to use the brakes to steer...if that helps you any.
ya...if catagory one is the smaller size, that's what it is. they are very good tractors tho.
-mike
Lou
02-10-2007 10:41:02
 Re: Massey 135 in reply to mike a. tenn., 02-10-2007 08:02:47
Tractor data.com has the 135 weight as 3645lbs. My brother has one that I borrow , its a great little tractor, but ive got a 10 or 12 ft rotory hoe that keeps the front end off the ground, the hydrolics are strong, but you would need to hang serious weight on the front. The tail might wag the dog.
