MF65 water leak
twigs_22
02-07-2007 19:02:36
Hi, my mf65 was overheating and loosing antifreeze. I had the radiator cleaned out professionally, replaced the water pump, thermostat, and upper and lower radiator hose. Good news is that it no longer over heats... bad news is it still sprays water when working hard. I noticed there is a 10 psi radiator cap but I think it should be a 7 psi. Would this cause the problem? What else should I check? I do not see bubbles when running. Any input is appreciated.
Eric in IL
02-08-2007 04:45:27
 Re: MF65 water leak in reply to twigs_22, 02-07-2007 19:02:36
Are you trying to keep the coolant level too high? It really only needs to be about a half inch above the tubes in the radiator. Might be worth a try.
JJ in Ok
02-08-2007 04:12:06
twigs: I had a similar problem with my cooling system. It would blow water out of the overflow tube when I worked my 65. I had a smoking problem that I figured out was the head gasket. I had comminucation between # 2 & 3 cylinders and the waterport that is between them. Coolant was leaking into the cylinders and pressuring up the radiator! JJ
