PTO speed vs Ground speed
Lloyd
09-03-2000 09:09:17
I do not have a clear understanding of ground pto vs. engine pto. Under what circumstances would you want to use one setting over the other?
Lee
09-29-2000 16:37:18
 Re: PTO speed vs Ground speed in reply to Lloyd, 09-03-2000 09:09:17
The ground speed PTO turns at or about one revolution for every 20" of ground travel.
B.C.
09-05-2000 06:50:01
One thing I've found ground speed useful for is unclogging sickle bar mowers.
1. Stop forward travel of tractor.
2. Shift into ground pto.
3. Reverse tractor and back up a short distance, like a foot or so. The pto shaft will be driven backward.
4. Shift Pto in neutral, shut down the tractor and get off and clear the clog.
It's handy if you're careful.
Tom from Ontario
09-03-2000 20:36:04
Sometimes, you want the pto moving in exact proprtion to ground speed. The ground speed pto worked very well with pto hay rakes, fertilizer spreaders and manure spreaders. There were also some mounted planters that required ground speed pto. Engine speed pto is the normal 540 rpm speed obtained at a particular engine speed, moving or stationary. Used for everything else other than than those uses mentioned above. If I'm not mistaken, I think M-F used to gear their ground speed speed pto at something like 19/52.
