1150 tractor engine swap
Wyatt Wie
02-06-2007 18:12:50
I have a 1150 with a 510 perkins that spun 2 main bearings. I have found 540 perkins in a 760 combine, will these interchange? I know the intake and exhaust manifolds are differnt but should swap. Does anyone know about the block and flywheel,is every thing drilled the same on the 540? Thanks
John - Central NY
02-07-2007 08:48:35
 Re: 1150 tractor engine swap in reply to Wyatt Wie, 02-06-2007 18:12:50
My 1150 now has a 540 from an 1155. Had to do some machining in the flywheel-clutch area, but no big deal.
1155puller
02-06-2007 18:45:37
Yes the AV8-540 and the AV8-510 perkins should be a direct bolt in. They are an identical block but i believe the 540 gets the extra 30 cubes from a lil longer stroke.
