MF30 diesel won't start
Rob(Wyo)
02-06-2007 17:26:08
Hi folks! Trying to get this old girl running. New injectors, pump. It was trying to fire before but the injectors werent spraying right. Put in new injectors and pump, cleaned the mouse nest out of the head and valves, figured it would go. I did re-use the old head gasket, and torqued it to specs. Now it won't fire at all, even with starting fluid. Was messing with it today and noticed the exhaust ports (manifold is off) are sucking air in, instead of blowing air out. Any suggestions as to what I have done wrong? I am just enough mechanic to get myself in trouble, so don't hesitate to mention the painfully obvious.
traper
02-06-2007 18:21:54
 Re: MF30 diesel won't start in reply to Rob(Wyo), 02-06-2007 17:26:08
Rob//Sounds to me your valves are too tight on adjustment.
