65 oil pan
JJ in Okla
02-06-2007 16:01:41
I'm cleaning up an old 1958 mod 65 (LP gas) I bought last fall. I had to pull the head to fix a leaking head gasket. (Water leaking between # 2 & 3 cylinders). The head is full of sludge! I'm thinking of pulling the oil pan to clean out the sludge in it and around the oil pump pickup tube. Is this something I need to do, or can I get things clean by changing the oil a few times after I get 'er running? Any Suggestions? Thanks JJ
Jerry Castleberry
02-07-2007 17:01:48
 Re: 65 oil pan in reply to JJ in Okla, 02-06-2007 16:01:41
JJ where do you live in Okla, I live in Claremore and I also have a MF propane, I'm real pleased with it Jerry C
Aaron Ford
02-06-2007 20:56:03
Amen to the previous post. My 65 gasser had the suction screen full of ..... insects. Flies, bugs, grsshoppers and many others were interred in my suction screen. While you have it off, you might consider slipping in new bearings or at least rebuildig the oil pump. I would definitely pull the pan. It's not that hard.
If you have a high speed connection, check out my myspace page. I have a slideshow that has pics of my engine when disassembled.
If ya have any questions, post 'em and folks here are pretty good at sorting them out.
HTH
Let's go Mountaineers,
Aaron
Aaron Ford
02-06-2007 20:57:27
 Re: 65 oil pan in reply to Aaron Ford, 02-06-2007 20:56:03
Oops, forgot the address. it is
www.myspace.com/expensivejunk
There should also be a video of the engine running, if it works.
Aaron
traper
02-06-2007 18:12:24
JJ//pull oil pan clean screen and pan other wise the crud you can,t get will wash down into pan clog screen.I have seen many a good engine blown by a cloged screen even if oil pressure looked good.
