fan belt
exhaust
02-06-2007 04:14:52
Good morning, I have a little problem was tring to install a fan belt on my mf-65 diesel and there is not enough room between the crankshaft pulley and the frame of the tractor to pull the belt through. Should the belt be installed from the top or the bottom. Thank you any help would be great.
Joe Ferguson
02-06-2007 17:26:24
 Re: fan belt in reply to exhaust, 02-06-2007 04:14:52
Hi
You may try to twist and pass the belt sideways
HTH
Joe Ferguson
DavidP, South Wales
02-06-2007 11:23:01
You should have enough room around the crank pulley to fit the belt. Is it by any chance the fan blades and radiator cowl that you are having trouble with? If so you will find a raised section of the cowl at about the one o'clock position which will allow fitting.
DavidP
exhaust
02-06-2007 13:37:23
 Re: fan belt in reply to DavidP, South Wales, 02-06-2007 11:23:01
David thanks for the reply but it is the crank pulley i"m having trouble with, going back to it tonight
David Bloodwood
02-06-2007 15:38:07
 Re: fan belt in reply to exhaust, 02-06-2007 13:37:23
What you're calling the 'frame" i assume is the big casting connecting the front of the engine block to the front axle assembly, steering post, etc. Is the 'well' inside this casting all full up with gunk? Mine was. I had to scrape out a lot of it to be able to get my old v-belt off.
Cheers, DB
