Location perkins serial number
traper
02-03-2007 19:14:28
I have a 135 m/f 1971 oil pan has 8/3/70 on it there is so much crud on it can,t find serial number. thanks for help in advance.Engine is ad3/152
traper
02-06-2007 18:44:20
 Re: Location perkins serial number in reply to traper, 02-03-2007 19:14:28
Dave//You are probley right it.s yellow with no markings on hood and dident see any other color under that//Thanks for come back.
traper
02-04-2007 10:37:35
Thanks guys // Acording to serial # 9a,110150 it,s a 71 or 72 depending whose data you look at.The tractor has a mf32 loader on it.
135 Fan
02-05-2007 16:16:22
 Re: Location perkins serial number in reply to traper, 02-04-2007 10:37:35
Are you sure it isn't an MF 20 with an MF 32 loader? The 20 is an industrial version of a 135. Dave
135 Fan
02-04-2007 09:30:53
Shouldn't your machine be a 1970 with 8/3/70? The Perkins serial number should be stamped on the block above the injection pump. The tractor serial number should be on the bottom of the dash. Dave
Don-Wi
02-04-2007 17:38:34
 Re: Location perkins serial number in reply to 135 Fan, 02-04-2007 09:30:53
Nah, that's just a casting date. I've done work on castings that were made 2-3 years or more before being machined to finish dimensions.
Of course, they weren't engine components either...
Donovan from Wisconsin
Archie in KY
02-04-2007 06:09:50
I have a 135 the book said the engine # is on the left side of engine put mine is on the right side.Archie
JJ. in B.C.
02-03-2007 20:24:00
Should be a plate on tha dash showing model and Ser.#..... .JJ.
