massey 44 no power out of coil when lead is conect
jeremy44
02-03-2007 16:32:44
when i have the lead from the positive side of the coil to the distributor it grounds itself and when i take it off there is power coming out of the positive side of the coil. what can be shorting out inside of the distibutor.
Gerald J.
02-03-2007 17:01:12
 Re: massey 44 no power out of coil when lead is co in reply to jeremy44, 02-03-2007 16:32:44
The points are only open half the time when the engine is running so there is a 50/50 chance they are closed. The condensor is not above fault, and its been known that the wire from coil to points has shorted where it enters the distributor.
Gerald J.
