MF135 3 cylinder
MichealP
01-31-2007 04:36:00
I need to rewire a MF135 3 cylinder. The ignition switch has 4 terminals, marked 1, 2, 3 and 4. What goes where?
Is it critical which way the solenoid is turned, i.e. small nub in, or out?
richard in nz
02-02-2007 01:11:20
 Re: MF135 3 cylinder in reply to MichealP, 01-31-2007 04:36:00
If your 135 is diesel and has a dynamo you should only have a 3 terminal switch with no 'ignition' position, i.e. spring loaded clockwise and counter clockwise. Terminal 1 is feed in from the battery via the ammeter. Terminal 2 is to the thermostart manifold heater. Terminal 3 is to the starter solenoid via the gearbox safty switch. A 4 position switch is used on alternator equiped tractors (and probably petrol tractors but I am not familiar with them) Terminal 1 live + from battery.
Terminal 2 to ignition warning lamp. Terminal 3 (spring loaded position) to thermostart.
Terminal4 (2nd spring loaded position) to starter.
michealp
02-06-2007 12:40:17
 Re: MF135 3 cylinder in reply to richard in nz, 02-02-2007 01:11:20
Sorry bout the delay in getting back to you.Thanks for that.
Do you have any idea what the purpose of the "control box" under the dash is for??
richard in nz
02-06-2007 23:19:39
 Re: MF135 3 cylinder in reply to michealp, 02-06-2007 12:40:17
The contol box is a Lucas RB106 voltage contol regulator and regulates the supply of charging from the output of the dynamo
michealp
02-07-2007 05:58:26
 Re: MF135 3 cylinder in reply to richard in nz, 02-06-2007 23:19:39
Has it any purpose on a tractor with an alternator?
richard in nz
02-07-2007 23:05:00
 Re: MF135 3 cylinder in reply to michealp, 02-07-2007 05:58:26
None, UNLESS 1) the regulator is not the original Lucas unit and has been replaced by one for the alternator, if an alternator without a built in regulator is being used. 2) the regulator terminals are being used as a junction box for the alternator.
