leaking LP tank valves
JJ in Ok
01-29-2007 03:07:34
I have a MF 65 LP tank that is leaking at one of the outlet valves. The fellow that I bought it from has put a ball valve after the collector tee. Is there some o-rings in the valves that I can replace? I am also going to replace thge brushes on the generator and starter while I am redoing the head. Is there a place that would have these replacements? Thanks
Gerald J.
01-30-2007 08:45:19
 Re: leaking LP tank valves in reply to JJ in Ok, 01-29-2007 03:07:34
An automotive electric shop should have brushes for starter and generator. I recommend also replacing bearings and bendix.
Gerald J.
mn.Chuck
01-30-2007 05:44:28
JJ, If you have a dealer close, the standard parts
book has several pages of the L.P. breakdown.
Some of the parts have a serial no. difference so
you may need that. I am not very acquainted with
the L.P. and not familiar with all the terminology
Chuck
