MF 65 head gasket
JJ in Okka
01-28-2007 16:19:53
I have been having problems with oil in water and water in oil! I pulled off the cyl head today and found what could be the problem. The two middle cylinders were leaking across the head gasket. I see a lot of carbon on the gasket and where water is getting into the cylinders. I can't see where the oil is getting into the water. I will have to get the head checked, I ran a straight edge asross it and couldn't see anything. I am courious that maybe the torque wasn't right and could have caused this. The head bolts didn't seem to be very tight. They were easy to break loose!
DavidP, South Wales
01-29-2007 01:39:41
 Re: MF 65 head gasket in reply to JJ in Okka, 01-28-2007 16:19:53
Hi,
Undertightening is a strong possibility and the order that it was pulled down will make a difference. Start in the centre and work out in increasing circles in several steps, then a final check.
It would be advisable to have the head skimmed as a precaution. No wisdom in saving a few dollars today to have to do it again tomorrow.
DavidP
