Hi There may be no defects at all... When the engine is cold the thermostat is closed and no circulation can be seen through the filling neck. There is no coolant recuperation bottle on these old tractors so if you fill radiator to the cap when the engine warms up the coolant will expand and throw the surplus by the overflow tube. So after the engine reach normal temperature the overflow will stop leaking. if you stop the engine and wait cool down you will see that coolant is lower...do"nt refill because it will throw the surplus again in warm up. The normal (cold engine) coolant level in radiator is 3 to 4 inches below the filling neck. When engine is at normal temperature coolant will be just at the filling neck. ----- ----- ----- ----- ----- -- That said...does the engine temperature gauge indicates overheat ? if yes..the thermostat may be stuck closed or installed backwards...is the fan belt tight if it slips the water pump does"nt turn fast enough. Warning ! Do not remove the radiator cap when engine is hot coolant under pressure will get out and burn your hands and arms. You may remove it by turning very slowly whith an insulated glove. My 2� Joe Ferguson
