oil coming back through air intake
George D. Borck
01-27-2007 14:40:49
i have massey f. 35 gas and the oil is coming out of the air intake leaking out from under the dash? what is causing this issue?
msb
01-28-2007 11:06:01
 Re: oil coming back through air intake in reply to George D. Borck, 01-27-2007 14:40:49
Does the tractor run on all cylinders? If it misses then I suspect a bad intake valve is the problem.I would run a compression check on the engine.
Don-Wi
01-27-2007 20:03:24
Does it deisel backwards a little when you shut it down? My 1600 does it once in a while so the air cleaner and hood gets a little oil on it then gets covered in dust. If it runs backwards at all, the air will go backwards through the exhaust and out through the air intake.
Donovan from Wisconsin
HowieNJ
01-27-2007 15:54:16
maybe she's full of water and pusing the oil out? did you open the air cleaner cup?
