mf135 gas, oil spec.
john JOLLIFF
01-27-2007 08:14:54
I would like to know the right oil to use in the winter and summmer for this tractor and the amount the crankcase holds.
i have a new filter and would like to change the oil thanks.
in sticks
01-27-2007 14:18:28
 Re: mf135 gas, oil spec. in reply to john JOLLIFF, 01-27-2007 08:14:54
Rotella 15-40
Rod in Smiths Falls, ON,
01-27-2007 13:03:25
I've had good luck using 15W40 in both my tractors, winter and summer. The Massey Harris 30 starts just fine with it and has good pressure winter and summer. The MF35 diesel gets plugged in for a few minutes if it's much below freezing, but I find it holds its pressure much better with the heavier oil than with 10W30 when snow blowing.
supergrumpy
01-27-2007 08:39:10
I used 30 to minimize oil consumption, fine for summer but forget starting the tractor below zero unless you have a block heater or such to thin the oil
went to good quality 10-30 and winter problems went away, slight increase in oil use but not bad
mine is 3cyl gas AG-152, has spin-on filter, ask for filter for AD-152, use a good filter, NAPA has them, I stopped using Fram based on comments found here
love the MF135
Gerald J.
01-27-2007 08:27:46
The same oil you use in your car, though the tractor oil can be thicker. I use 10W30 in my MF-135 and it takes 6 quarts. Look for an oil that meets SAE SJ rather than SM according to some arguments.
Gerald J.
