MH U joints
mike phelan
01-26-2007 05:09:59
Can and where do you get new U JOINT or chain coupling between transmision shaft and drive shaft behind the clutch housing, mine has play and makes noise when in neutral with clutch disengaged, thanhs mike or is this normal
Newton Miller
01-26-2007 05:49:21
 Re: MH U joints in reply to mike phelan, 01-26-2007 05:09:59
Hello if its making much noise that means your engine is sitting out of allignment. to need to move some of the shims under the engine mounts or add some. then apply some good heavy chain lube to the coupler chain
