Oil pressure gauge, MH 30
Steven Forrest
01-25-2007 11:12:11
I have a gauge to put on to measure oil pressure, any suggestions on where it should be connected to engine?
It is a Continental F162 motor.
Thanks, Steve.
Jason Beluschok
01-25-2007 11:46:37
 Re: Oil pressure gauge, MH 30 in reply to Steven Forrest, 01-25-2007 11:12:11
Steve,
There is a "T" shaped fitting that is in the oil filter can. The one line goes to the fitting that is coming out of the block(above the dip stick) The other line that is connected to that "T" fitting points down and goes back to your oil gauge. I have the same engine in my Silver King and Im pretty sure the 30 has the same set up. Hope this helps! Any more questions just ask.
Alberta Mike
01-25-2007 13:33:49
 Re: Oil pressure gauge, MH 30 in reply to Jason Beluschok, 01-25-2007 11:46:37
Another place is on the engine's right side near the back below the tappet cover. Should be a pipe plug in there now, 1/8" ips I believe the plug is. That will also provide you with engine oil pressure.
